Unspecified error when calling AddFiniteExtrudedProtrusion ST9 API
My code is in Delphi, but I think .Net or VB users can interpret.
I have written a short program in Delphi RAD 2010 and am getting an unspecified error in the AddFiniteExtrudedProtrusion method of Models.  The code below works up to the last statement.
Procedure DrawProfile;
var
   ObjDocs       : Documents;
   objPart       : PartDocument;
   objProfSets   : ProfileSets;
   objProfSet    : ProfileSet;
   objProfs      : Profiles;
   objProf       : Profile;
   objRefPlns    : RefPlanes;
   objRels2D     : Relations2D;
   objRel2D      : Relation2D;
   objLines2D    : Lines2D;
   objLine2D     : Line2D;
   objModels     : Models;
   objModel      : Model;
   ProfileArray  : OleVariant;
begin
   StartSE;
   objDocs:=objApp.Documents;
   objPart:=objApp.Documents.Add('SolidEdge.PartDocument', TempDoc) as Partdocument;
   objProfSets:=objPart.ProfileSets;
   objProfSet:=objProfSets.Add;
   objProfs:=objProfSet.Profiles;
   objRefPlns:=objPart.RefPlanes;
   objProf:=objProfs.Add(objRefPlns.Item(3));
   objLines2D:=objProf.Lines2d;
   objLine2D:=objLines2D.AddBy2Points(0,0,1,0);
   objLine2D:=objLines2D.AddBy2Points(1,0,1,1);
   objLine2D:=objLines2D.AddBy2Points(1,1,0,1);
   objLine2D:=objLines2D.AddBy2Points(0,1,0,0);
   objRels2D:= Relations2D(objProf.Relations2d);
   objRel2D:=objRels2D.AddKeypoint(objLines2D.Item(1),igLineEnd, objLines2D.Item(2),igLineStart,true);
   objRel2D:=objRels2D.AddKeypoint(objLines2D.Item(2),igLineEnd, objLines2D.Item(3),igLineStart,true);
   objRel2D:=objRels2D.AddKeypoint(objLines2D.Item(3),igLineEnd, objLines2D.Item(4),igLineStart,true);
   objRel2D:=objRels2D.AddKeypoint(objLines2D.Item(4),igLineEnd, objLines2D.Item(1),igLineStart,true);
   objProf.End_(igClosed);
   Dist:=1;
   ProfileArray:=objProfs.Add(objProf) as Profiles;
   objModels:=objPart.Models;
      // The below statement will run, but gives an unspecified error
   objModel:=objModels.AddFiniteExtrudedProtrusion(1, ProfileArray, igRight ,
                                                      Dist, EmptyParam,EmptyParam,EmptyParam,EmptyParam);
end;
