Update Object on Visible True False
I am setting a group's visible property to True/False from a Form button:
objGroup.Visible = True/False
No problem when setting to False - the group vanishes instantly.
However when setting to True the group does not appear without a manual zoom pan or fit.
I tried an ugly workaround of objDoc.ActiveSheet.Activate()
Not able to find a Update/Refresh/Regen method on the App, Draft Document, Sheet or the Group object itself.
Any help is highly appreciated.
~Tushar
Re: Update Object on Visible True False
OK found it:
Dim objSWindow As SolidEdgeDraft.SheetWindow = objApp.ActiveWindow
objSWindow.Update()
