Update Sketch
Hi
I am trying to update the sketch through programming using VB6, but i am unable to find the control for "update sketch".
But in Solid Edge you can find this command
1)Right Click on any feature-Edit Profile
2) Go to Main Menu Tool-Sketches-Update Sketch
If some one know about this please help me for finding this control
Thanking You
Posted by: Sandeep Shewale
Post date: 10/10/2008 2:46:14 AM
RE: Update Sketch
I haven't researched it, but this may be a case where it's easier to use Jason's Solid Edge Spy to view the StartCommand value and use that value in your code.
'some code
theEdge.StartCommand(value)
'some more code
Posted by: Michael Frayser
Post date: 10/10/2008 3:03:59 AM
RE: Update Sketch
Thanks for reply
i will tyr with the commandID but still i am nuable to get the commandID to update the sketch, if some one knows about this please help
Post date: 10/12/2008 6:47:48 PM
