Update and retrieve ass'y mass
I'm trying to update and return the mass of an assembly.
However the code I have keeps on crashing SE (st6 & 7)
        Dim objPhyProps As SolidEdgeAssembly.PhysicalProperties
       objPhyProps = objdoc.PhysicalProperties
        Dim dblMass As Double
        Dim dblVolume As Double
        Dim dblArea As Double
        Dim dblCofMass() As Double
        Dim dblCofVolume() As Double
        Dim dblGlobalMoments() As Double
        Dim dblPrincipalAxis1() As Double
        Dim dblPrincipalAxis2() As Double
        Dim dblPrincipalAxis3() As Double
        Dim dblPrincipalMoments() As Double
        Dim dblRadiiOfGyration() As Double
        Dim bIsSick As Boolean
        Dim bUpdateStatus As Boolean
        Call objPhyProps.Update() 'update mass
        Call objPhyProps.GetAssemblyPhysicalProperties( _
              Mass:=dblMass, Volume:=dblVolume, _
              Area:=dblArea, CenterOfMass:=dblCofMass, CenterOfVolume:=dblCofVolume, _
              GlobalMoments:=dblGlobalMoments, PrincipalAxis1:=dblPrincipalAxis1, _
              PrincipalAxis2:=dblPrincipalAxis2, PrincipalAxis3:=dblPrincipalAxis3, _
              PrincipalMoments:=dblPrincipalMoments, RadiiOfGyration:=dblRadiiOfGyration, _
              IsSick:=bIsSick, UpdateStatus:=bUpdateStatus)
        MsgBox(dblMass) 'show the ass'y mass!
 Please help Man Indifferent
Maarten Elings | Mechanical Engineer
Re: Update and retrieve ass'y mass
Solved it!
        objDoc = objApplication.ActiveDocument
        Dim dblMass As Double = 0
        Dim dblVolume As Double = 0
        Dim dblArea As Double = 0
        Dim dblCofMass As Array = Array.CreateInstance(GetType(Double), 3)
        Dim dblCofVolume As Array = Array.CreateInstance(GetType(Double), 3)
        Dim dblGlobalMoments As Array = Array.CreateInstance(GetType(Double), 3)
        Dim dblPrincipalAxis1 As Array = Array.CreateInstance(GetType(Double), 3)
        Dim dblPrincipalAxis2 As Array = Array.CreateInstance(GetType(Double), 3)
        Dim dblPrincipalAxis3 As Array = Array.CreateInstance(GetType(Double), 3)
        Dim dblPrincipalMoments As Array = Array.CreateInstance(GetType(Double), 3)
        Dim dblRadiiOfGyration As Array = Array.CreateInstance(GetType(Double), 3)
        Try
        Catch ex As Exception
        End Try
        MsgBox(dblMass)
Amazings, that's what I was looking for!
Works Great to me, thanks
Looks the the community samples may be getting overlooked by some!
They're certainly saving me a lot of time figuring stuff out when I'm pressed for time...
Community Samples on GitHub
Your specific query
