Update on save as status ST8
Hello everybody,
I checked  Update on save as status on an asm with this code
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objDocuments As SolidEdgeFramework.SolidEdgeDocument = Nothing
Dim objPhyProps As SolidEdgeAssembly.PhysicalProperties = Nothing
objApplication = Activator.CreateInstance(Type.GetTypeFromProgID("SolidEdge.Application"))
objApplication.Visible = True
objApplication.DisplayAlerts = False
objDocuments = objApplication.Documents.Open("C:\test.asm")
objDocuments = objApplication.ActiveDocument
objPhyProps = objDocuments.PhysicalProperties
objPhyProps.UpdateOnFileSaveStatus = True
objPhyProps.UseQuantityOverrideMass = True
objPhyProps.Update()
but when i save this assembly, mass properties does not update.
if I check it with mouse mass properties update well.
anybody has an idea?
Re: Update on save as status ST8
Thank you BalamuruganM But I know how to update physical properties. I'm in ST8 and I need to update physical properties with Solid Edge save. So I checked by code the checkbox : Update on file save in physical Properties windows. with this code objPhyProps.UpdateOnFileSaveStatus = True and it work. the problem is when I checked the checkbox by code and a draftman change asm and save, Solid Edge does not update Mass ???? If I checked the checkbox by mouse click and a draftman change asm and save, Solid Edge update Mass. Why? Thank you
IR number : 7601269 It will be fix on ST9
Thanks for filing an IR so that it will get fixed in the future.
Jason Newell
Applications Architect
www.jasonnewell.net
Hello everybody!
I know I open it again but I recently instaled ST9 and still doesn't work even if they said it was fix on ST9.
(IR number : 7601269)
I submit again to GTAC and they tell  the code is available so they won't go further.
Any idea to help me on that?
This the code who checked the option Update on save as but doesn`t react as check manually.
I think you have the wrong IR number.  When I reviewed IR 7601269 it is for "User Section AD tab is visible with 'Customized Metrics Calculator' not loaded" on another SIemens PLM product line.
oopss ! it's 7601296
Hello everybody!
I know I open it again but I recently instaled ST10 and still doesn't work.
I checked Update on file save on an asm in physical Properties windows with this code
This is the code who checked the option Update on file save but doesn`t react as check manually.
and the check box is checked.
but when i save this assembly, Physical Properties are stil out-of-date.
if I check it by mouse click Physical Properties are up-to-date.
I realy realy need to check (Update on file save) on all old asm by code.
last year I submit to GTAC and they tell the code is available so they won't go further.
If my code is worng, what is the good one?
Thanks in advance.
See attach video
(view in My Videos)
If we check (Update on file save) checkbox  by code with sendkeys, it work.
        AppActivate("Solid Edge ST8")
        objApplication = Marshal.GetActiveObject("SolidEdge.Application")
        'open physical properties windows
        My.Computer.Keyboard.SendKeys("{F12}")
        If Not (objApplication Is Nothing) Then
            Marshal.ReleaseComObject(objApplication)
            objApplication = Nothing
        End If
        GC.Collect()
        GC.WaitForPendingFinalizers()
        GC.Collect()
        'position on (Update on file save) checkbox
        For i = 1 To 21
            My.Computer.Keyboard.SendKeys("{TAB}")
            End If
            GC.Collect()
            GC.Collect()
        Next
        'check (Update on file save) checkbox
        My.Computer.Keyboard.SendKeys(Chr(32))
        End If
        GC.Collect()
        GC.Collect()
        'position on close button
        For i = 1 To 2
            End If
            GC.Collect()
            GC.Collect()
        Next
        'close physical properties windows
        My.Computer.Keyboard.SendKeys("{ENTER}")
        objDocuments.Save()
        objDocuments.Close()
        End If
        GC.Collect()
        GC.Collect()
        End
