Updating Draft with Assembly open
I'm running ST3 on Windows 7, 64 bit.
What I'm experiencing if an Assembly file is open and I try and run some code to update a draft file i'm getting huge delays.  It will eventually finish but the diffference in time between having an assembly open or not is 20 times.
Has anyone else experienced this and if so come across with a solution.
The delays seem to be the same on a 32 bit XP machine...with ST3.
Posted by: sean tormey
Post date: 1/26/2012 7:37:34 AM
