Updating Variables using 'Call objVariables.Edit' statement
Solid Edge Comunity,
I am working on a Visual Basic program that is used to drive graphics in a SolidEdge asm file creating an animation.  The following Call objVariables.Edit statements work well for changing one variable at a time.
     Call objVariables.Edit("V1649", XPos)
     Call objVariables.Edit("V1644", YPos)
     Call objVariables.Edit("V864", ZPos)
Is there a way to update two to three variables simultaneously?  (With a single statement)
That would greatly improve the visual movement during the animation.
Thanks for any help.
Don
Re: Updating Variables using 'Call objVariables.Edit' statement
Don,
look for SEApplication.DelayCompute and SEApplication.ScreenUpdating.
HTH
Gerald
Thanks, I will look there.
Don
I tried the following.
    Set objApp = GetObject(, "SolidEdge.Application")
    objApp.ScreenUpdating = False
    objApp.ScreenUpdating = True
Solid Edge screen updates with (objApp.ScreenUpdating = True) statement.
Thanks for the help.
Don
