Reply
Updating Variables?
[ Edited ]
Hi All,
Can anybody tell me that is it possible to edit & update the part variables without opening the part file?
Also what exactly does "Solid Edge Vtable interfaces for Geometry and Structure" means?
Posted by: Prasad Pawar
Post date: 8/11/2008 10:31:19 PM
RE: Updating Variables?
[ Edited ]
Hi Prasad,
U have to open the part to update the variables.But u can do it
by "objApp.Visible = false" ,with this solid edge instance will open in the background and will not visible to us.
u can do all your work on the part with setting visible property to false.
Posted by: Hemant Pawar
Post date: 8/11/2008 10:46:53 PM
[ Edited ]
Hemant,
Thanks for your quick reply but actually i am familier with this method. What i am doing is i am updating almost 25-30 parts from an assembly. So that it is taking time to open and update the parts. (i know this is the only way to cope with it). It was just a trial wheather we can do it in other way or not.
Anyways thanks.
Post date: 8/12/2008 12:25:14 AM
[ Edited ]
Prasad,
I don't know of any other way to update the variables.  Sorry
Posted by: Jason Newell
Post date: 8/12/2008 8:09:00 PM
[ Edited ]
Jason,
Actually i also dont think there may be any other way to update the variables.
Anyways thanks for your quick reply
Post date: 8/12/2008 8:27:47 PM
[ Edited ]
All,
Somewhere i heard about exposing a variable and you can update it without opening the part file.
Is this possible means did anybody try it? After exposing a variable, it shows the name and value in Custom Properties. I tried changing it but it gave me no error as well no updation of variable.
Any views?
Post date: 9/1/2008 11:56:04 PM
[ Edited ]
So how you update the assemby ? you open all parts and then update assembly ?
Posted by: Rafa P
Post date: 3/23/2010 11:06:32 AM
