Use Marshal to Create New Solid Edge Object in .NET?
I know it is recommended to connect to an existing existance of Solid Edge via .NET like this:
system.Runtime.InteropServices.Marshal.GetActiveObject("SolidEdge.Application")
What is the equivalent way to open the Solid Edge application?
Searching the forums, I found this:
MarshalEx.CreateObject("SolidEdge.Application")
...but it only looks like that is applicable for the compact framework.
-Brent
Posted by: Brent Newsom
Post date: 5/31/2006 7:15:14 AM
RE: Use Marshal to Create New Solid Edge Object in .NET?
Hi Brent,
Jason already has an answer to this under Articals > Solid Edge.
http://www.jasonnewell.net/portal/Articles/SolidEdge/tabid/72/ctl/Details/mid/418/ItemID/1/Default.a...
Hope this helps,
James
Posted by: James Singleton
Post date: 6/2/2006 12:42:32 AM
Brent,
Adding to what James said, MarshalEx is a custom class that I wrote because CreateObject fails as described in the article.
I might also mention that I think CreateObject works correctly in v2.0 of the framework.
Posted by: Jason Newell
Post date: 6/8/2006 6:06:24 AM
