Use of CreateOrEditSimplifiedAssembly command
Hi everybody,
Can't manage to make this code works, always get an exception when creating simplified assembly.
Do you have any clues ?
Sub Main()
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objdocuments As SolidEdgeFramework.Documents = Nothing
Dim objDocument As SolidEdgeDocument = Nothing
Dim objASSY As SolidEdgeAssembly.AssemblyDocument = Nothing
Try
objApplication = CType(Marshal.GetActiveObject("SolidEdge.Application"), SolidEdgeFramework.Application)
If objApplication.ActiveDocumentType = DocumentTypeConstants.igAssemblyDocument Then
objASSY = objApplication.ActiveDocument
If objASSY.IsAssemblySimplified Then
objASSY.UpdateSimplifiedAssembly()
Else
Dim OCCArray() = Nothing
Dim OCCArray2() = Nothing
[b][i][color=#ff0000] objASSY.CreateOrEditSimplifiedAssembly(0, OCCArray, 1, objassy.occurences.count, OCCArray2)[/color][/i][/b]
End If
End If
Catch ex As Exception
If Not (objApplication Is Nothing) Then
Marshal.ReleaseComObject(objApplication)
objApplication = Nothing
End If
End Try
End Sub
Posted by: Romuald
Post date: 9/25/2013 1:23:45 PM
I managed to make things works :
Sub Main()
Try
Else
Dim NbOCC As Long = objASSY.Occurrences.Count
Dim EcludeRangeRatio As Double = 0.5
Dim NumOccurrenceExclude As Long = 0
Dim arrayRetExcludeOccs(0) As Object
Dim arrayRetIncludeOccs() As Object = System.Array.CreateInstance(GetType(Object), NbOCC)
For i = 0 To NbOCC - 1
arrayRetIncludeOccs(i) = objASSY.Occurrences(i)
Next
objASSY.CreateOrEditSimplifiedAssembly(NumOccurrenceExclude, arrayRetExcludeOccs, EcludeRangeRatio, NbOCC, arrayRetIncludeOccs)
End If
End If
End If
End Try
End Sub
Posted by: Romuald
Post date: 10/10/2013 3:57:23 AM
