Useful Solid Edge Developer Community Links
I wanted to bring to your attention the following links for those of you who would like to keep up with activities regarding the Solid Edge Developer Community. I've been very busy over the past several months getting everything setup and am just now getting to a point where I'm ready to start blogging a lot and making lots of videos.
For those of you who follow me on YouTube, please note that I have created a new YouTube channel that focuses exclusively on custom programming. I also tweet when I post a blog or video so that's another good way to keep up.
My goal, as always, it to reach as many people as possible. You can help by subscribing to my YouTube channel, favoriting my videos (only if you like them of course), retweeting\favoriting my tweets and mentioning my blogs posts when you get the chance. Thank you all for the help.
Solid Edge SDK
Solid Edge 2019 SDK
Solid Edge ST10 SDK
Solid Edge ST9 SDK
Solid Edge ST8 SDK
Solid Edge ST7 SDK
Solid Edge ST6 SDK
Developer Tools
Spy for Solid Edge (Install | Source code)
Microsoft Visual Studio
GitHub
Solid Edge Community
Solid Edge Samples
NuGet
Interop.SolidEdge NuGet Package
SolidEdge.Community NuGet Package
SolidEdge.Community.Reader NuGet Package
Microsoft
Solid Edge Community Templates
Visual Studio Community 2015 (Free & full featured)
Tushar Suradkar
Surf and Code
Kabir Costa
Tutorial Solid Edge Programming (YouTube)
Jason Newell
JasonNewell.NET
JasonNewell.NET (YouTube)
Jason Newell
Solutions Architect
www.jasonnewell.net
13 REPLIES 13
Re: Useful Solid Edge Developer Community Links
Thanks for your great work, Jason
Héctor Pelayo Izquierdo
Engineering Department, JAE Ingeniería y Desarrollos, S.L.
Solid Edge ST9 MP5 | NX 9
Development: VB.NET
Added @Tushar's site to the list. Let me know if you guys come up with any good links.
Jason Newell
Solutions Architect
www.jasonnewell.net
Thanks Jason. Can you kindly point the link to (keeping the text same)
http://www.surfandcode.in/2014/01/index-of-all-tutorials-on-this-solid.html
which is a good starting point for navigating to all other areas of the site.
like this:
www.SurfAndCode.in
~Tushar
Done
Jason Newell
Solutions Architect
www.jasonnewell.net
@jnewell
Jason, is it plausible  for you have a version of Interop.SolidEdge that is compatible with Universal Windows Platform (UWP) apps in the future. Was thinking of doing some revision manager API stuff in a windows 10 app but not sure if it even possible!
Good question and one that I'm not up-to-speed on enough to even answer at this point. If I may suggest, please create a new thread on this topic here in the forum so that we can continue the discussion.
Jason Newell
Solutions Architect
www.jasonnewell.net
Added C# & Visual Basic sections. Specifically, I have ran into new language features recently that I was previously unaware of so I wanted to capture the links for future reference. Good stuff.
Jason Newell
Solutions Architect
www.jasonnewell.net
I  tried to install Solid Edge Community Templates on Windows 10, but the VS2013 Ultimate Extensions and Updates installer keeps failing with a message
The extension requires a version of the .NET Framework that is not installed
I tried to install it from Microsoft Visual Studio Gallery running the vsix file with same result.
The installed Framework version is above 4.6 , the id from the registry to the version is 394802
Best regards
Ramon Ruiz
I was able to install it modifing the extensions.vsixmanifest file following this instructions
https://github.com/paulcbetts/SaveAllTheTime/issues/39
First I downloaded the VSIX file from https://visualstudiogallery.msdn.microsoft.com/fd1878fc-6520-4eeb-95e5-1b8b27da875e
Then I changed the vsix extension to zip
I unzipped it and opened extension.vsixmanifest
I searched and found the Dependencies line and changed the Framework version to Version="[4.5,)"
Repacked everything as zip, renamed it to vsix and installed it.
