UserDefinedPatterns
I'm trying to create a user defined pattern for a profile consisting of two holes.  The code always bombs out on the last statement.  I believe there to be an array issue, but I'm not sure how to fix it.  any idea's?
Dim oProfile As SolidEdgePart.Profile = Nothing
Dim oProfileCollection As SolidEdgePart.Profiles = Nothing
Dim oProfiles(6) As SolidEdgePart.Profile
Dim oHole As SolidEdgePart.Hole = Nothing
Dim oHoleData As SolidEdgePart.HoleData = Nothing
Dim oUDpattern As SolidEdgePart.UserDefinedPattern = Nothing
oProfile = m_PartDoc.ProfileSets.Add.Profiles.Add(oRefPlane(0))
oProfile.Holes2d.Add(x(0), y(0))
oProfile.Holes2d.Add(x(1), y(1))
lngStatus = oProfile.End(igProfileClosed)
If lngStatus 0 Then
    MsgBox("Invalid Profile")
End If
oProfileCollection = oProfile.Parent.profiles
For i = 1 To oProfileCollection.Count
    oProfiles(i) = oProfileCollection.Item(i)
Next
oHoleData = m_PartDoc.HoleDataCollection.Add(HoleType:=igRegularHole, HoleDiameter:=dHoleDiameter * SE, _
                                        TreatmentType:=igTappedHole, ThreadDescription:=m_sTapSize, _
                    ThreadDepth:=m_oBushing.TappedHoleDepth * SE)
oHole = m_PartDoc.Models.Item(1).Holes.AddFinite(oProfileCollection.Item(1), igLeft, m_dLTB * SE, oHoleData)
oUDpattern = m_PartDoc.Models.Item(1).UserDefinedPatterns.AddByProfiles(i, aProfiles, oHole)
Posted by: Bob Reinkemeyer
Post date: 2/11/2009 3:59:37 AM
3 REPLIES 3
RE: UserDefinedPatterns
I took the working VB6 code and upgraged to .net.  this is the warning I recieved from the above code.
UPGRADE_WARNING: Couldn't resolve default property of object objProf.Parent.Profiles
Appearenty default properties aren't allowed in .net.  Any idea how to get around this one?
Post date: 2/13/2009 2:18:42 AM
I have just had a problem with UserDefinedPatterns.
I had this line in C++:
PatternsPtr spPatterns = m_model->GetUserDefinedPatterns();
Untill the last SolidEdge version it worked fine but for the current version (100), it returns NULL.
So I had to protect the code after this line with
if (spPatterns != NULL)
Maybe your problem is that your "m_PartDoc.Models.Item(1).UserDefinedPatterns" is NULL too?
Adar
Posted by: Adar Shtainhart
Post date: 3/9/2009 12:37:05 AM
Thanks Adar, I'll give that one a try today.
Post date: 3/9/2009 1:48:07 AM
