Using ChamferSetbackValue1 and ChamferSetbackValue2
I'm having no luck using ChamferSetbackValue1 and 2. I have a model with 4 chamfers and I'm trying to change the setbacks to different amounts. Chamfer.count is coming back with 4. I am doing the following and am have no luck. I error out every time.
Any advice would greatly be appreciated.
models = partDocument.Models
model = models.Item(1)
chamfers = model.Chamfers
chamfer1 = chamfers.Item(1)
chamfer2 = chamfers.Item(2)
chamfer1.ChamferSetbackValue1 = 0.001
chamfer1.ChamferSetbackValue2 = 0.001
chamfer2.ChamferSetbackValue2 = 0.002
Re: Using ChamferSetbackValue1 and ChamferSetbackValue2
Hi @LenC
pls see my answer to your previous post Modifying-4-chamfers-with-Visual-Basic
JB
SE ST10
