Reply
Using WhereUsedCriteria and FindWhereUsed in C++
[ Edited ]
Hello all,
I have created macro in VB.net for copy job using revision manager 'WhereUsedCriteria' and 'FindWhereUsed'
The code is as given below:
[b]objApplication.WhereUsedCriteria("*.dft", False) = existingJob
objRevDft = objApplication.FindWhereUsed(varstrPsm)[/b]
But the same logic is not working in c++. Please help me in using 'WhereUsedCriteria' and 'FindWhereUsed' in C++.
Thank You
Posted by: Shruthi M
Post date: 2/13/2012 9:58:16 PM
Re: Using WhereUsedCriteria and FindWhereUsed in C++
[ Edited ]
Supposing existingJob is a string containing the start folder for your search and varstrPsm is a _variant_t containg the string of the filename to look for, the following lines should do what you want.
objApplication.PutWhereUsedCriteria("*.dft", VARIANT_FALSE, existingJob);
objRevDft = objApplication.FindWhereUsed(varstrPsm);
Posted by: Martin Bernhard
Post date: 2/17/2012 2:00:11 PM
[ Edited ]
Thank You Martin,
Your code worked. Smiley Happy
Post date: 2/19/2012 11:36:34 PM
