Using objBalloons.AddByTerminator on a DrawingView
I can add a balloon to a line on the sheet easy enough:
objBalloon1 = objBalloons.AddByTerminator(objLine, 0.75, 0.015, 0, True)
But I can't add a balloon to a line in a drawing view:
objBalloon1 = objBalloons.AddByTerminator(objDVLine, 0.75, 0.015, 0, True)
It gives me the following error:
Exception from HRESULT: 0x80040223
ST2 VB2010
Posted by: Terry Tyson
Post date: 9/26/2011 10:42:09 AM
RE: Using objBalloons.AddByTerminator on a DrawingView
Terry,
try with
objBalloon1 = objBalloons.AddByTerminator(objDVLine.Reference, 0.75, 0.015, 0, True)
Posted by: Wolfgang Kunert
Post date: 9/26/2011 8:31:12 PM
Wolfgang,
Thanks for the reply. This has gotten me closer to where I need to be. I get a balloon but I don't seem to have much control over that balloon. Specifically, the .Leader and .BreakLine don't seem to work. Here is my code.
Imports System.Runtime.InteropServices
Module Module1
    Sub Main()
        Dim objApp As SolidEdgeFramework.Application = Marshal.GetActiveObject("SolidEdge.Application")
        Dim objDoc As SolidEdgeDraft.DraftDocument = objApp.ActiveDocument
        Dim objSheet As SolidEdgeDraft.Sheet = objDoc.ActiveSheet
        Dim objView As SolidEdgeDraft.DrawingView = objSheet.DrawingViews.Item(1)
        Dim objBalloons As SolidEdgeFrameworkSupport.Balloons = objSheet.Balloons
        Dim objDVBalloons As SolidEdgeFrameworkSupport.Balloons = objView.Sheet.Balloons
        Dim objBalloon1 As SolidEdgeFrameworkSupport.Balloon = Nothing
        Dim objLine As SolidEdgeFrameworkSupport.Line2d = Nothing
        Dim objDVLine As SolidEdgeDraft.DVLine2d = Nothing
        objLine = objSheet.Lines2d.Item(1)
        objDVLine = objView.DVLines2d.Item(10)
        'objBalloon1 = objBalloons.AddByTerminator(objLine, 0.75, 0.015, 0, True)
        objBalloon1 = objDVBalloons.AddByTerminator(objDVLine.Reference, 1, 1, 0, True)
        objBalloon1.TextScale = 1.5
        objBalloon1.BalloonText = "%{PART NUMBER|GP}"
        objBalloon1.Leader = True
        objBalloon1.BreakLine = True
        ReleaseObject(objDVLine)
        ReleaseObject(objLine)
        ReleaseObject(objBalloon1)
        ReleaseObject(objDVBalloons)
        ReleaseObject(objBalloons)
        ReleaseObject(objView)
        ReleaseObject(objSheet)
        ReleaseObject(objDoc)
        ReleaseObject(objApp)
    End Sub
    Private Sub ReleaseObject(ByRef objComObject As Object)
        If objComObject IsNot Nothing Then
            Marshal.ReleaseComObject(objComObject)
            objComObject = Nothing
        End If
    End Sub
End Module
Thanks for your help.
Post date: 9/27/2011 5:09:47 AM
Wolfgang, thanks for the help.
Here is what's working. Now I just need to take it and run with it.
Module Module1
    Sub Main()
        objBalloon1 = objBalloons.AddByTerminator(objDVLine.Reference, 1, 1, 0, False)
        objBalloon1.AddVertex(0.1, 0.1, 0)
    End Sub
        End If
    End Sub
End Module
Post date: 9/27/2011 5:56:40 AM
For a better relative placement of the balloon, use the following code:
Dim objTerminator As Object = Nothing
Dim x,y,z As Double
objBalloon1.GetTerminator(objTerminator, x, y, z, keyPoint)
objBalloon1.AddVertex(x + 0.01, y - 0.01, z)
Posted by: Martin Bernhard
Post date: 9/27/2011 6:13:43 AM
Awesome Martin, thanks again. This is just what I was looking for.
Post date: 9/27/2011 6:49:20 AM
