VB 6.0 Dimension in Draft...
Hi.....
i'm korean.
My English is still baby yet. So please understand...
nothing but
Printing Dimension in Draft
ex
    For m = 1 To objDrawingView.DVLines2d.count
        Set line = objDrawingView.DVLines2d.Item(m)
         ret1 = line.DrawingView.Defaults_ShowHiddenEdges
          Set SEdim = sedims.AddLength(line)
    Next m
result : this case is lines overlap
this method fail.... The Problems and Solutions about ??
Question.
1. set hidden line disable method ?
2. dimension lines overlap disable method?
thank...
Sorroy..English....
    Next m
nothing but
Posted by: eom younghwee
Post date: 6/22/2011 4:34:25 PM
RE: VB 6.0 Dimension in Draft...
Try this
Set SEdim = sedims.AddLength(line.Reference))
Posted by: BONNAUDET eric
Post date: 7/6/2011 11:07:36 PM
