VB.NET: CreateObject() & MarshallEx
Jason,
I've read the "article" about the SolidEdge CreateObject() bug in VB.NET and the solution.
But in many examples I've found the class MarshallEx: what's the differences ?
Could you explain more deeply the MarshallEx class ?
Compliments and Regards!
Posted by: francesco marcheluzzo
Post date: 11/8/2006 10:31:06 PM
RE: VB.NET: CreateObject() & MarshallEx
Francesco,
I created the MarshalEx class because the default Marshal class didn't provide a CreateObject() method that did what we needed. It is simply a custom class that allows you to call CreateObject() to start Solid Edge without failing like the VB.NET provided CreateObject() does.
HTH
Posted by: Jason Newell
Post date: 11/12/2006 1:33:51 PM
