VB.NET and Solid Edge Occurrences
I am a 2.5 year programmer in vb.net, but new to solid edge. I am attempting to first, get a solid edge assembly and its properties. This works well and is pretty straightforward. Secondly, I am trying to traverse through its occurrences in order to get a full BOM from the document. The Occurrence count comes back with 9, so I know it is reading them. I have tried many of the examples that I've found on this site, and also from the Solid Edge programmers guide, to no avail. I always error on the "For Each objOccurrence In objOccurrences", objOccurrence returns NOTHING.
I am soon to give up and just use VB6, which I have working. But I'd rather not...
Any help would be appreciated, I thank you!
(Your site is very good!!)
Jennece
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim asm As SolidEdgeFramework.Application
' Connect to a running instance of Solid Edge.
asm = System.Runtime.InteropServices.Marshal.GetActiveObject("SolidEdge.Application")
If asm.ActiveEnvironment "Assembly" Then
' An assembly document is not open, notify user and then exit.
MsgBox("This program must be run with an assembly document open." & Chr(10) & Chr(13) & "Please open an assembly document and retry.")
Exit Sub
End If
' Get the assembly information by calling this recursive function.
ObtainAssemblyInformation(asm.ActiveDocument, 1)
End Sub
Sub ObtainAssemblyInformation(ByVal objDoc As SolidEdgeAssembly.AssemblyDocument, ByVal intLevel As Integer)
On Error Resume Next
Dim objOccurrence As SolidEdgeAssembly.Occurrence
Dim objOccurrences As SolidEdgeAssembly.Occurrences
objDoc.Activate()
objOccurrences = objDoc.Occurrences
Dim intc As Integer = objOccurrences.Count()
' Iterate through all of the parts in the current assembly.
If Not objOccurrence Is Nothing Then
' Make sure it should be included in the BOM by checking the IncludeInBom flag.
If objOccurrence.IncludeInBom Then
' Find the object in the array, create if necessary
AddSolidEdgeClassItem(objDoc, objOccurrence, intLevel)
' If this is a subassembly, then recurse into it unless this is a top level parts listing.
If (objOccurrence.Subassembly) Then
ObtainAssemblyInformation(objOccurrence.OccurrenceDocument, intLevel + 1)
End If
End If
End If
Next
End Sub
Posted by: Jennece Wilson
Post date: 2/15/2007 1:51:49 AM
RE: VB.NET and Solid Edge Occurrences
For Each isn't possible with some Solid Edge object collections, try this instead:
For i As Integer = 1 To objOccurrences.Count
Dim objOccurrence As SolidEdgeAssembly.Occurrence = objOccurrences.Item(i)
Posted by: Wolfgang Kunert
Post date: 2/15/2007 2:11:35 AM
Go to my resources page and download the 2006 developer conference examples. Specifically look at Track 4, Demo 4. Here is the code.
Imports SolidEdgeAssembly
Imports SolidEdgeFramework
Imports System.Runtime.InteropServices
Module Module1
Sub Main()
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objAssembly As SolidEdgeAssembly.AssemblyDocument = Nothing
Try
objApplication = Marshal.GetActiveObject("SolidEdge.Application")
objAssembly = objApplication.ActiveDocument
ProcessLinks(objAssembly)
Console.WriteLine("Press Enter to continue.")
Console.In.ReadLine()
Catch ex As Exception
Console.WriteLine(ex.Message)
Console.WriteLine(ex.StackTrace)
Finally
If Not (objAssembly Is Nothing) Then
Marshal.ReleaseComObject(objAssembly)
End If
If Not (objApplication Is Nothing) Then
Marshal.ReleaseComObject(objApplication)
End If
End Try
End Sub
Sub ProcessLinks(ByVal objParent As SolidEdgeAssembly.AssemblyDocument)
Dim objOccurrences As SolidEdgeAssembly.Occurrences = Nothing
Dim objOccurrence As SolidEdgeAssembly.Occurrence = Nothing
Console.WriteLine(objParent.FullName)
Try
objOccurrences = objParent.Occurrences
If Not (objOccurrences Is Nothing) Then
For Each objOccurrence In objParent.Occurrences
ProcessLinks(objOccurrence, 1)
Next
End If
Throw ex
Finally
If Not (objOccurrence Is Nothing) Then
Marshal.ReleaseComObject(objOccurrence)
End If
Marshal.ReleaseComObject(objOccurrences)
End If
End Try
End Sub
Sub ProcessLinks(ByVal objParent As SolidEdgeAssembly.Occurrence, ByVal level As Integer)
Dim objSubOccurrences As SolidEdgeAssembly.SubOccurrences = Nothing
Dim objSubOccurrence As SolidEdgeAssembly.SubOccurrence = Nothing
Dim i As Integer
For i = 0 To level
Console.Write(vbTab)
Next
Console.WriteLine(objParent.Name)
Try
objSubOccurrences = objParent.SubOccurrences
If Not (objSubOccurrences Is Nothing) Then
For Each objSubOccurrence In objParent.SubOccurrences
ProcessLinks(objSubOccurrence, level + 1)
Next
End If
Finally
If Not (objSubOccurrence Is Nothing) Then
Marshal.ReleaseComObject(objSubOccurrence)
End If
Marshal.ReleaseComObject(objSubOccurrences)
End If
End Try
End Sub
Sub ProcessLinks(ByVal objParent As SolidEdgeAssembly.SubOccurrence, ByVal level As Integer)
Dim i As Integer
For i = 0 To level
Next
Try
Next
End If
Finally
End If
End If
End Try
End Sub
End Module
Posted by: Jason Newell
Post date: 2/15/2007 2:15:24 AM
Oh my gosh... I tried the for i = ... and it worked, came back with a valid
_com object. I am going to take a good look at the code example sent also.
I cannot tell you how amazed I am at the quick (not to mention accurate) help!
I have put your site as a favorite, and will try to help others if/when I can.
Thanks so much!
Jennece
P.S. Stayed at Red Rock Canyon SP for a week once, loved it so much I have always since wanted to move to Oklahome...
Post date: 2/15/2007 2:24:30 AM
Jennece,
I'm not sure if you've found it yet but you've got to check out my Solid Edge Spy application. It's a free product that I wrote for SE developers. It will help you quickly get up to speed on the Solid Edge runtime COM object model.
p.s. Glad your stay in Oklahoma was pleasant. I've traveled all over the U.S. and I can honestly say there is no other place I'd rather live.
Post date: 2/15/2007 3:11:33 PM
Hi Jennece,
It is possible to get For Each to work like this:
For Each objOccurrence In CType(objOccurrences, IEnumerable)
I sometimes use this to avoid messy code.
Cheers
Calum
Posted by: Calum McLellan
Post date: 2/15/2007 6:56:58 PM
I'm trying to retrieve the face color from the parts in an Assembly with several levels of subassembies.
I saw another post that used for example:
oASM.Occurrences.Item(1).SubOccurrences.Item(8).ThisAsOccurrence.FaceStyle.stylename
This allowed me to retrieve the 1st level suboccurrences color.
Why doesn't this work for another level:
oASM.Occurrences.Item(1).SubOccurrences.Item(1).SubOccurrences.Item(14).ThisAsOccurrence.FaceStyle.stylename
and this so on
oASM.Occurrences.Item(1).SubOccurrences.Item(1).SubOccurrences.Item(14).SubOccurrences.Item(1).ThisAsOccurrence.FaceStyle.stylename
and I can retrieve their quantities using the same format:
oASM.Occurrences.Item(1).SubOccurrences.Item(1).SubOccurrences.Item(14).SubOccurrences.Item(1).ThisAsOccurrence.Quantity
Why can't I get deeper subassemblies face colors.
Posted by: Rita Ellis
Post date: 7/19/2011 4:06:40 PM
