VC++ 2010
Does anyone have an example of accessing Solid Edge with Visual C++ 2010? All the examples I have are in an older version and I can't get any of them to work.
Posted by: Terry Tyson
Post date: 4/18/2012 10:27:04 AM
Re: VC++ 2010
What doesn't work? Depending on the version of the compiler used in older versions there may be a few simple compile errors that need to be fixed. But I am unaware of any major issues. I open and convert projects to VS 2010 with little difficulty.
Posted by: R.D. Holland
Post date: 5/3/2012 9:15:17 AM
