Value of get_FamilyVariable()
Hello all,
I need value of resulted objec from get_FamilyVariable function. Resulted object is of System.Object type but probably there is possibility to chnge type to some
SolidEdgeSomething.Variable var = (SolidEdgeSomething.Variable) famMems.get_FamilyVariable(iVar);
but I do not know which is the correct SE type.
Does anybody know?
Jara SolidEdgePart.FamilyMembers)part11Doc.FamilyMembers;for (intiVar = 1; iVarfamMems.FamilyVariableCount; iVar++)System.Objecto1 = famMems.get_FamilyVariable(iVar);
Posted by: Jara Ctverak
Post date: 4/29/2009 1:53:00 AM
