Variables f type Dimension
Hello All,
I need to edit the formula in Variable table for sheet metal, part and assembly files when the formula has xls in it.
I am not able to retrieve formulas of type of dimension if I use objDocument.Variables.
It gives me only variables of type "Var" type.
Please suggest some ideas or provide me sample code.
Thank You
Posted by: Shruthi M
Post date: 5/6/2013 12:38:34 AM
Take a look at my post here and see if that helps any:
[url=http://www.jasonnewell.net/forums/solid-edge-programming/5068-create-new-assembly-and-add-subassembl... Tips[/url]
Posted by: Terry Tyson
Post date: 5/6/2013 7:52:00 AM
