View orientation
How to get the current view  orientation in 3D document(Part,Assembly) using API?
view orientaion e.g.: font view,isometric view,diametric view,trimetric view..
thanks.
Amani
Re: View orientation
Tushar 2nd Gear
2nd Gear
Hi Amani:
I believe the Window and View objects of the current document should contain the information you seek.
Dim oDoc As SolidEdgePart.PartDocument = seApp.ActiveDocument
Dim oWin As Window = oDoc.Windows(1)
oWin.View.GetCameraEx...
Further some knowledge external to SE like view origin, view target, etc. will also be required.
Check if View.GetCamera contains the information you need.
~Tushar
I actually mean how to get the list of named view (named view manger) and get if one of then is  used in the current document.
For example , to set a specific view I use :
 m_application.StartCommand(SolidEdgeConstants.PartCommandConstants.PartViewISOView)
just i want to verify witch orientation view is used already.
Thanks.
