Viewer AxSEDraftX1
Hello!
VB.Net
With a Solid edge viewer control, AxSEDraftX1 from SEDraft.ocx , I want to print drawing with the command PrintOut()
and I want to print without the windows printer
How to display the windows printer?
this is my code:
AxSEDraftX1.Fit()
AxSEDraftX1.BackColor = Color.White
AxSEDraftX1.MouseAction = "ZoomArea"
AxSEDraftX1.DraftFile = ("C:\Dessin2\1285\12856\128569AA1.dft")
AxSEDraftX1.PrintOut()
thank you!
Posted by: Plante Sylvain
Post date: 1/12/2013 9:08:38 AM
Viewer AxSEDraftX1
If you use the PrintOut method, you see the dialog to print.
In this dialog you can see the windows printers.
For the print without dialog you can loop the sheets and print the sheet single.
Dim objShts As SEDRAFTXLib.Sheets = AxSEDraftX1.Sheets
For i = 0 To objShts.Count - 1
Dim objSh As SEDRAFTXLib.Sheet = objShts.Item(i)
objSh.PrintOut(1)
Next
Posted by: JR
Post date: 1/23/2013 4:44:50 AM
