What's the SE Product Dev. Center email address ?
Hello.
Does anybody know the email address of the SE Product Development Center?
MS Outlook is not working properly in my machine, so I cant' see any email address to send the dump file generated by SE.
Also. What's an IR(what does it mean) and how can I open it? Is it through a webkey account in SE website?
Thanks!
Re: What's the SE Product Dev. Center email address ?
In the registry, under HKCU\Software\Unigraphics Solutions\Solid Edge\Version 106\CrashLog,
there is the CrashLogEmailAddress defined (rmseanalyze@ugs.com).
An IR is an Incident Report and can be created on the GTAC site using your webkey.
Thanks a bunch Martin!
