When the SE Doc is open, I want to fill "file properties", not "custom" attribute!
Hi, all.
Such as the title of my question, please.
When the SE Doc is not open, I  can fill  these "file properties"(such as :"summaryinfomation","projectinfomation") , but if the doc is open, I do not it!
Thanks!
Posted by: fat kids
Post date: 8/12/2009 4:57:08 PM
RE: When the SE Doc is open, I want to fill "file properties", not "custom" attr
Hi fatkids,
if a SE Doc is open you must set the properties in the opened Document in the SolidEdge.Application.
JR
Posted by: JR
Post date: 8/12/2009 7:46:19 PM
Tanks, I can filled it use "set_value".
Posted by: fat kids
Post date: 8/13/2009 5:25:10 PM
