Where can I find the ST4 SDK?
I have the ST3 SDK, but I cannot remember where I downloaded it from...
Where can the ST4 SDK be found?
Posted by: Misa Takaki
Post date: 11/28/2011 11:26:58 AM
RE: Where can I find the ST4 SDK?
As it stands today, you cannot legally download it from anywhere.  You get access to it by installing Solid Edge.  Specifically, see the following paths:
C:\Program Files\Solid Edge ST4\Custom
C:\Program Files\Solid Edge ST4\SDK
Posted by: Jason Newell
Post date: 12/7/2011 1:27:24 PM
Hi Janson,
This is prasad, present i am working on solidedge API(customization).when i edit the part/sub assembly in assemblypathfinder.then i getting the that edited model doc, i need to traverse from edited model doc to thier parent ,after ding some chnges again i need to go to parent and do something,like upto toplevel document.
for this problem please give some idea...........
Prasad
Posted by: prasad k
Post date: 12/8/2011 10:42:40 PM
Thanks Jason. I did find it there after I posted.
I appreciate the response.
Post date: 12/9/2011 4:43:25 AM
