Where is the SE ST Programming Guide ?
I can't find it: should I look into SE ST help (i din't install it yet)?
Posted by: francesco marcheluzzo
Post date: 10/7/2008 3:03:03 AM
RE: Where is the SE ST Programming Guide ?
Francesco,
you can find it under C:\Program Files\Solid Edge ST\Program\ResDLLs\0009\mu28000.pdf, if you have an English version installed.
For different languages, you may look into a different ResDLLs subfolder (other than 0009). The complete path may also differ, if you haven't installed SE ST it under the default path.
Posted by: Martin Bernhard
Post date: 10/8/2008 3:25:15 AM
Once you have it installed, you can get to it from the following screenshot.
Posted by: Jason Newell
Post date: 10/8/2008 7:53:29 AM
Could someone share it for those who are still on V20? Is there any separate version of it such as a pdf for download? TIA
Posted by: Ozlem ILDAY
Post date: 10/16/2008 9:43:17 PM
The Guide is on the Solid Edge Documents web site for download.
Post date: 11/12/2008 2:11:21 AM
Do you need a web key for that pdf file?
Posted by: Snow Mackenzie
Post date: 11/16/2008 10:58:49 PM
