WhereUsedCriteria : can the filter include multiple entries
I am using the Revision Manager API and using the where used command.
I am trying to set the WhereUsedCriteria to look for only Draft and Assembly files.
Is this possible.  The format is WhereUsedCriteria([filter], [search subfolders]).
I have used:  RevApp.WhereUsedCriteria("*.dft", True)  which finds all Draft files
and I know:  RevApp.WhereUsedCriteria("*.*", True)  will find all file types.
Is there a way to combine *.dft and *.asm in one filter string or do I have to call this twice?
Thanks.
Carl Breving
Posted by: Carl Breving
Post date: 10/24/2011 7:15:44 PM
