Which events can/can't be accessed by macro programming - examples !!
Hi guys !
Got some problems by accessing events thru macro, and like to know which events can/can't be accessed by macro programming !! --- made a post on UGS forum with the aim, too....
To me it seems like code from vb6 doesn't work for events on Framework 2.0 and Studio2005, cause of EventHandler missing ;; tried to get it working, and found some lines in "Customizing SolidEdge" doing well, but can't get a clue why!!
Whats a bit strange to me, is the declearation with ISEApplicationEvents_Event cause it's not in the Studio-build interop. dlls but the code recognizes it & program's working = ?
cant find a working declaration for FileUIEvents, too...
Whats the mystery about it ?
** AppEvents Here **
Public Class Form1
    Public WithEvents AE As SolidEdgeFramework.ISEApplicationEvents_Event
    Public SE_app As SolidEdgeFramework.Application
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        'Get SE object
        SE_app = GetObject(, "SolidEdge.Application")
        AE = SE_app.ApplicationEvents
    End Sub
    Public Sub AE_AfterDocumentSave(ByVal doc As Object) _
    Handles AE.AfterDocumentSave
        MsgBox("AE.AfterDocumentSave")
    End Sub
    Public Sub AE_AfterCommandRun(ByVal CommandID As Integer) _
    Handles AE.AfterCommandRun
        MsgBox("AfterCommandRun= " & CommandID)
    End Sub
    Public Sub AE_BeforeCommandRun(ByVal CommandID As Integer) _
    Handles AE.BeforeCommandRun
        MsgBox("BeforeCommandRun= " & CommandID)
    End Sub
End Class
A working Code from vb6 from "Julian Guillo"
>Dim objSE As SolidEdgeFramework.Application
>Dim WithEvents objAppEvents As SolidEdgeFramework.ApplicationEvents
>Private Sub Form_Load()
>    Set objSE = GetObject(, "solidedge.application")
>    Set objAppEvents = objSE.ApplicationEvents
>End Sub
>Private Sub objAppEvents_AfterCommandRun(ByVal theCommandID As Long)
>    MsgBox "Command ID=" & theCommandID & " was activated"
>End Sub
>Private Sub objAppEvents_AfterDocumentOpen(ByVal theDocument As Object)
>    MsgBox "Welcome to document " & theDocument.FullName
>End Sub
>Private Sub objAppEvents_BeforeDocumentSave(ByVal theDocument As Object)
>    'Calculate weight
>    'Write weight into a custom property.
>End Sub
THX Linuz
Posted by: Linus Hechinger
Post date: 11/19/2008 9:29:06 PM
