Word wrap
Guys,
I added a TextBox from Vb into SE Draft file using TextBox1 = objTextBoxes.Add(X, Y, 0). I can specify the height, width etc...When I select the TextBox in SE and right click and edit properties, I see that the Word wrap is unchecked...how can I check that Word wrap?? Please help!!!
Umctigers
Posted by: chinna raju
Post date: 12/13/2011 9:57:52 AM
RE: Word wrap
Hi Umctigers,
word wrap behaviour of a TextBox object is controlled by its PlacementType property.
Posted by: Wolfgang Kunert
Post date: 1/10/2012 2:39:29 AM
