Work Sheet
Hi, I use DraftDataAPI to extract EMF files from the draft without running Solidedge. It works fine when a work sheet is the active sheet. But when a background sheet is the active sheet, I only get background sheets. Is there a way to get the work sheets even if the active sheet is a background sheet? Thank
Posted by: Patrick Fortier
Post date: 9/21/2009 7:38:24 AM
