add Coordinate Dimensions
Hi ,
I just want to add coordinate dimension in drawing view. Just consider one rectangular object in drawing view, 1st line is coordinate origin, and I want to add coordinate dimension for remaining 3 lines.
App=Marshal. Getactiveobject("solid edge.application)
Doc=app.activedocument
Sheet=doc.activesheet
Views=sheet.drawingviews
View=views.item(1)
Lines2d = view.dvlines2d
Dims=sheet.dimensions
Line2d1=lines2d.item(1)
Dim a,b,c,d as double
Line2d1.getstartpoint(a,b)
dims.addcoordinateorigin(line2d1,a,b,0,true)
for I=2 to lines2d.count
Line2d=lines2d.item(i)
Line2d.getstartpoint(c,d)
dims.addcoordinate(Line2d1,a,b,0,true,line2d,c,d,0,true)
Next
Endsub
While running this code, it consider all start points as zero,
Second thing
All the dimensions are added on lower left corner of the sheet...
can you help me for this problem
Balaji
