add part like drag from part library?
How to add a part to assembly enviroment,  just like drag a part file to assembly enviroment? Active the assembly command after draged part to assembly enviroment?
Posted by: assassin 007
Post date: 7/5/2009 11:01:11 PM
RE: add part like drag from part library?
Search AddByFilename in the SolidEdge Programming Help.
Massimo
' Note: This Visual Basic 6 example is for reference only as it has not been converted to Visual Basic .NET.
' Occurrences.AddByFilename
Private Sub Form_Load()
    Dim objApp As SolidEdgeFramework.Application
    Dim objDoc As SolidEdgeAssembly.AssemblyDocument
    Dim objParts As SolidEdgeAssembly.Occurrences
    Const TESTFILE = "T:\vbtests\testcases\chead.par"
    ' Report errors
    Const PI = 3.14159265358979
    ' Create/get the application with specific settings
    On Error Resume Next
    Set objApp = GetObject(, "SolidEdge.Application")
    If Err Then
        Err.Clear
        Set objApp = CreateObject("SolidEdge.Application")
        Set objDoc = objApp.Documents.Add("SolidEdge.AssemblyDocument")
        objApp.Visible = True
    Else
        Set objDoc = objApp.ActiveDocument
    End If
    ' adding a part document from a file to the assembly document
    Set objParts = objDoc.Occurrences
    Call objParts.AddByFilename(OccurrenceFileName:=TESTFILE)
    ' USER DISPLAY
    ' Release objects
    Set objApp = Nothing
    Set objDoc = Nothing
    Set objParts = Nothing
End Sub
Posted by: Massimo Magris
Post date: 7/5/2009 11:11:42 PM
Hi, Massimo, thanks! But the result is that the part is fixed. I want that user can set part 3d relationships after added the part.
Post date: 7/6/2009 5:32:25 PM
so just create a VB form with a kind of "explorer".
When user drag & drop a file from the form to SolidEdge with an assembly open,
SolidEdge automatically start the command and ask for relationship.
Massimo
Post date: 7/6/2009 7:24:34 PM
This is an old VB6 example i did for someone else.
It simulates the command "Place Part". The only thing you must provide is the filename.
It uses the "OnPlacePartUI" event.
Well, just try it. Regards,
Julian
(Back from my only 1 week holidays)
Posted by: Julian Guillo
Post date: 7/7/2009 6:48:01 AM
