batch .NET program to convert Solid Edge files to PDF
In Solid Edge ST2 we can save directly a PDF file manually with "Save As". To do that Solid Edge ST2 uses a special printer called: "Solid Edge Velocity PS Printer 2.0".  I need a batch program: could you suggest me the .NET code to convert in PDF the current drawing?
Posted by: francesco marcheluzzo
Post date: 2/10/2010 3:51:11 AM
RE: batch .NET program to convert Solid Edge files to PDF
Hi francesco,
saving the current draft file as pdf is quite simple:
Dim dftDoc As SolidEdgeDraft.DraftDocument = Nothing
dftDoc = CType(seApp.ActiveDocument, SolidEdgeDraft.DraftDocument)
dftDoc.SaveAs(pdfPathName)
Posted by: Wolfgang Kunert
Post date: 2/10/2010 6:38:11 AM
Perfect, thanks a lot!
Post date: 2/11/2010 10:17:09 PM
Re: RE: batch .NET program to convert Solid Edge files to PDF
SolidEdgeDev wrote:
Hi Francesco,
dftDoc.SaveAs (pdfpathname)
Thank you,Wolfgang
The code for batch conversion of Solid Edge files to PDF is of great help.
