batch conversion
i'm totaly new in Solid Edge development and in VB programming ! But i've to develop a program or a VB script.
My need is as follow :
1) i extract a Solid Edge's drawing file from an Oracle database.
2) i've to convert this file in pdf format
3) i store the pdf file into database
Steps #1 and #3 are already writed (with c++)
Is there somebody who can explain me how to :
- launch Solid Edge in batch mode
- open drawing file
- do a "save as" in pdf format
Other question : in case where drawing file is associated with a 3d model, is 3d model requiered for conversion ?
Thank you very much for your answers
Best regards
thm
Posted by: Thierry Maire
Post date: 3/7/2007 11:20:46 PM
RE: batch conversion
Thierry,
I'll see what I can come up with tonight. What version of Solid Edge and service pack are you going to want to do this in?
Posted by: Jason Newell
Post date: 3/8/2007 5:28:59 AM
Thank you very much Jason
I use Solid Edge v18 (standard install) and my os is Windows Xp Pro sp2.
Best regards.
Thierry
Post date: 3/8/2007 3:12:50 PM
Thierry,
The "Save As PDF" option was added to V19 if I'm not incorrect. That means we'll have to come up with some other mechanism for the conversion.
Post date: 3/9/2007 1:17:15 AM
This is what I recommend. With the Solid Edge viewer API, you can extract EMF's of the Sheets.
Then I would use: PDFDoc Scount to convert the EMF's into PDF's.
Post date: 3/9/2007 4:31:41 AM
yes, it's also what i thought !
I found in Solid Edge's directory an example nammed PrintDFT, and I planed to use PDFCreator for pdf file creation.
We must keep in mind that no user interaction is allowed, this conversion must be a batch treatment.
All is a bit "blurred" for me, if you could help me a bit or say me where to find necessary informations...
Thank you very much !
Thierry
Post date: 3/10/2007 12:10:42 AM
