c# SE AddIn own button in the menu bar
I like to make with an SE AddIn with my own register card at the menu bar. There should be a Button witch starts then my function.
How those this work in C# that I can make a new Register Card and this Button in SE?
thanks for your help
Re: c# SE AddIn own button in the menu bar
It's unclear what you mean by "register card". For developing a Solid Edge addin using C#, watch the following video.
I also recommend that you review the SolidEdgeCommunity / Samples on GitHub. Specifically, download and extract the C# Samples. Once extracted, open .\AddIns\MyAddIn\MyAddIn.sln for a more complete example.
Jason Newell
Applications Architect
www.jasonnewell.net
Thank you for your help
It works now
