changing Author Property using C# - save failes..
I'm trying to convert all the files in my folder so I'll be the Author of them.
reading the file Author properties is OK, yet when I'm changing the Author value to "polk" and saving:
1. property.GetType().InvokeMember("Value", System.Reflection.BindingFlags.SetProperty, null, property, new object[]
                            {"polk"});
2. propertySets.Save();
In the debugger I see that after passing line 1 the value was updated correctly.
Yet it seems that line 2 has no effect since when opening the file again the author didn't changed..
When I try to save with "properties.Save();" I get exception.
What am I doing wrong?
P.S:
Based my code according to Jason in this post: http://www.jasonnewell.net/Community/Forums/tabid/55/aft/1437/Default.aspx
Posted by: joseph polk
Post date: 10/25/2011 6:47:10 PM
RE: changing Author Property using C# - save failes..
try to acces and modify the author by using the SummaryInfo object of the SolidEdgeDcoument object instead of using the file properties.
Posted by: Wolfgang Kunert
Post date: 10/26/2011 10:29:33 PM
Thanks Wolfgang!
That helped
for the case that others will stumble upon the same issue my code below - any remarks or code refinements are welcomed
using System;
using System.Runtime.InteropServices;
namespace MyMacro
    class Program
        static void Main(string[] args)
            SolidEdgeFramework.Application application = null;
            SolidEdgeFramework.SolidEdgeDocument document = null;
            SolidEdgeFramework.SummaryInfo summInfo = null;
            Type type = null;
            try
                // Get the type from the Solid Edge ProgID
                type = Type.GetTypeFromProgID("SolidEdge.Application");
                // Start Solid Edge
                application = (SolidEdgeFramework.Application)Activator.CreateInstance(type);
                // Make Solid Edge visible
                application.Visible = true;
                // Turn off alerts. Weldment environment will display a warning
                application.DisplayAlerts = false;
                string sDestinationFile = @"C:\htuli2.par";
                SolidEdgePart.PartDocument _objDoc = (SolidEdgePart.PartDocument)application.Documents.Open(sDestinationFile);
                // Get a reference to the active document
                document = (SolidEdgeFramework.SolidEdgeDocument) application.ActiveDocument;
                summInfo = document.SummaryInfo;
                // Setting Author to new value
                summInfo.Author = "zZzZz Polk";
                // Updating file status to inWork...
                document.Status = SolidEdgeFramework.DocumentStatus.igStatusInWork;
                document.Save();
                //document.SaveAs(sDestinationFile);
            catch (System.Exception ex)
                Console.WriteLine(ex.Message);
            finally
                if (application != null)
                    Marshal.ReleaseComObject(application);
                    application = null;
Post date: 10/27/2011 12:46:08 PM
