create a profile on a coor sys
It's my first time I post on this forum, I use it a lot to search but I'm lost on this one.
I create and edit a part in an assembly.
Now I want to add a profile on the ZX plane of the coordinate system.
Here is my code so far:
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objDocuments As SolidEdgeFramework.Documents = Nothing
Dim objassy As SolidEdgeAssembly.AssemblyDocument = Nothing
Dim objlayouts As SolidEdgeAssembly.Layouts = Nothing
Dim objlayout As SolidEdgeAssembly.Layout = Nothing
Dim objOccurances As SolidEdgeAssembly.Occurrences = Nothing
Dim objOccurance As SolidEdgeAssembly.Occurrence = Nothing
Dim objPart As SolidEdgePart.PartDocument = Nothing
Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
Dim objProfiles As SolidEdgePart.Profiles = Nothing
Dim objProfile As SolidEdgePart.Profile = Nothing
Dim objCoorSyss As SolidEdgePart.CoordinateSystems = Nothing
Dim objCoorSys As SolidEdgePart.CoordinateSystem = Nothing
Dim objCoorPlane As SolidEdgeGeometry.Plane = Nothing
Dim objRelations2d As SolidEdgeFrameworkSupport.Relations2d = Nothing
Dim objRelation2d As SolidEdgeFrameworkSupport.Relation2d = Nothing
Dim objDims As SolidEdgeFrameworkSupport.Dimensions = Nothing
Dim objDim As SolidEdgeFrameworkSupport.Dimension = Nothing
Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d = Nothing
Dim objLine2d As SolidEdgeFrameworkSupport.Line2d = Nothing
Dim objarcs2d As SolidEdgeFrameworkSupport.Arcs2d = Nothing
Dim objarc2d As SolidEdgeFrameworkSupport.Arc2d = Nothing
Dim objModels As SolidEdgePart.Models = Nothing
Dim objModel As SolidEdgePart.Model = Nothing
Dim objset As SolidEdgeFramework.SeObjectType = Nothing
Dim aProfiles AsArray
Dim sketch_name AsString
Const pi = 3.1415926535897931
' Connect to a running instance of Solid Edge
objApplication = Marshal.GetActiveObject("SolidEdge.Application")
' Get a reference to the documents collection
objDocuments = objApplication.Documents
' Connect to the assembly document
objassy = objApplication.ActiveDocument
' Get a reference to the layout sets collection
objlayouts = objassy.Layouts
' Get the selected layout
objlayout = objApplication.ActiveSelectSet.Item(1)
'get the name of the selected layout
sketch_name = objlayout.Name
'create part file
objOccurance = objassy.Occurrences.AddByTemplate(sketch_name & ".par")
'open the new part file
objPart = objApplication.ActiveDocument
' Get a reference to the profile sets collection
objProfileSets = objPart.ProfileSets
'Add a new profile set
objProfileSet = objProfileSets.Add()
' Get a reference to the profiles collection
objProfiles = objProfileSet.Profiles
' Get a reference to the Coor Systems collection
objCoorSyss = objPart.CoordinateSystems
'Connect to the first Coor System
objCoorSys = objCoorSyss.Item(1)
'objCoorPlane = objCoorSys.Plane(SolidEdgePart.CoordinateSystemFeatureConstants.seCoordSysZXPlane)
'Add a new profile
objProfile = objProfiles.Add(objCoorSys.Plane(3))
Thanks for your help.
Posted by: Stephan Morin
Post date: 10/26/2010 4:20:45 AM
