custom named view shortcut
Hi, I trying to create macro which will set specific named view in view manager.
I didn't find possibility to set my custom view by some keyboard shortcut directly in SE.
I can create shortcut just for View manager, but not for view.
I use two or three custom views, so my my idea is to do three macros and run them by keyboard shortcuts.
I have no idea how I can apply the named views from views manager.
I guess the "SolidEdgeFramework.View.ApplyNamedView(Object)" could possibly work, but I can't find the way how to assign the custom view to the object variable.
Could anyone help me?
Thank you
Re: custom named view shortcut
Simply passing the name of the view should suffice. See below.
[STAThread]
static void Main(string[] args)
    var application = SolidEdgeCommunity.SolidEdgeUtils.Connect();
    var window = (SolidEdgeFramework.Window)application.ActiveWindow;
    var view = window.View;
    view.ApplyNamedView("Test");
Jason Newell
Solutions Architect
www.jasonnewell.net
Hi Jason, It works perfect! Smiley Happy
Thank you
