dft layer
Hello, i have a question for you.
I need enable or disable a layer in a dft files,(SE. Version 18 sp 10) by visual basic code.
I use visual basic 2005, have you any examples or any suggestions ?
Mauro
Posted by: Mauro Mignozzetti
Post date: 10/15/2007 2:36:04 AM
RE: dft layer
If you have not done so already, you need to download and install my free Solid Edge Spy application. It will help you qucikly find stuff like this.
Sub Main()
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objDraft As SolidEdgeDraft.DraftDocument = Nothing
Dim objSheet As SolidEdgeDraft.Sheet = Nothing
Dim objLayers As SolidEdgeFramework.Layers = Nothing
Dim objLayer As SolidEdgeFramework.Layer = Nothing
Try
objApplication = Marshal.GetActiveObject("SolidEdge.Application")
objDraft = objApplication.ActiveDocument
objSheet = objDraft.ActiveSheet
objLayers = objSheet.Layers
objLayer = objLayers.Item("Layer1")
objLayer.Show = False
Catch ex As Exception
Finally
If Not (objLayer Is Nothing) Then
Marshal.ReleaseComObject(objLayer)
End If
If Not (objLayers Is Nothing) Then
Marshal.ReleaseComObject(objLayers)
End If
If Not (objSheet Is Nothing) Then
Marshal.ReleaseComObject(objSheet)
End If
If Not (objDraft Is Nothing) Then
Marshal.ReleaseComObject(objDraft)
End If
If Not (objApplication Is Nothing) Then
Marshal.ReleaseComObject(objApplication)
End If
End Try
End Sub
Posted by: Jason Newell
Post date: 10/16/2007 5:12:13 PM
RE: dft layer
hy jason,
thank you very much for your reply.
All work correctly.
Mauro
Post date: 10/16/2007 8:55:17 PM
