dissolve Reference to SubASM - how to??
AnyOne tried to dissolve a Reference?
I made it it works for the first level...
But I've got the problem with References to SubAsm-Parts - don't know how to dissolve it...
see the snippet below,  I only get the SubAsm as an Occurrence, but not the Part the relation is related to
I know that references are there - for each hierarchical level - , but how to find the right next step reference ?
thx for any hint so that I can search in the right corner, too
Dim Relations As SolidEdgeAssembly.Relations3d
        Relations = Occurrence.Relations3d()
        For Each rel As Object In Relations
            If rel.type = SolidEdgeConstants.ObjectType.igPlanarRelation3d Then
  Dim PlanarRelation3d As SolidEdgeAssembly.PlanarRelation3d = rel
                Dim ref1 As SolidEdgeFramework.Reference
                Dim ref2 As SolidEdgeFramework.Reference
                Dim Occ1 As SolidEdgeAssembly.Occurrence
                Dim Occ2 As SolidEdgeAssembly.Occurrence
                Dim RefItem1 As Object           ' RefPlane or Face / SolidEdgePart.RefPlane
                Dim RefItem2 As Object '      " / "   or SolidEdgeAssembly.AsmRefPlane
                If rel.GetElement1(True).type = SolidEdgeConstants.ObjectType.igReference Then
                    ref1 = rel.GetElement1(True)
                    Occ1 = PlanarRelation3d.Occurrence1
                    RefItem1 = ref1.Object     [...]
                End If
               If  ...  'also with GetElement2
Posted by: Linus Hechinger
Post date: 9/1/2010 9:23:19 PM
