duplicator for an occurrence with all relations !!
I'm thinking bout a duplicator of an asm occurrence, with all relations
so u just duplicate it,
change one dim, and you've got it fixed on a slightly different location.
but my problem is, that there's nothing for cloning the object occurrence.
So i tried to rebuild relations with the info from the "old" occurence.
BUT i can't figure out how 2 access the "old" relations and using
the infos 2 rebuild them on the "new" occurrence.
I'm workin with vb...
I've picked up the occurrence from the selectset, and brought it into the asm again, deleted the baserelation...and
here's my code 2 recognize the basic 2 relation types.
- pleease help
 For i As Integer = 1 To OldOccRelations.Count
            If OldOccRelations.Item(i).Type = SeRealtions.igPlanarRelation3d Then
                Dim OldRelation As SolidEdgeAssembly.PlanarRelation3d = OldOccRelations.Item(i)
                MsgBox(i & " = PlanerRelation")
                'NewOccRelations.AddPlanar(OldRelation.GetElement1(False), OldRelation.GetElement2(False), OldRelation.NormalsAligned, Constrain1, Constrain2)
            ElseIf OldOccRelations.Item(i).Type = SeRealtions.igAxialRelation3d Then
                Dim OldRelation As SolidEdgeAssembly.AxialRelation3d = OldOccRelations.Item(i)
                MsgBox(i & " = AxialRelation")
            Else
                MsgBox(i & " = NOT SUPPROTED !")
            End If
        Next
THX  linus
Posted by: Linus Hechinger
Post date: 2/3/2009 2:14:52 AM
RE: duplicator for an occurrence with all relations !!
do I need 2 build references ? like below ?
but still can't figure out how 2 get the faces ....
OldOcc is the selected Occurrence for duplication
RefOcc = the Occurrence OldOcc is related to
NewOcc is the duplicated one:
       'select RelationType
                Dim RefOcc = OldRelation.Occurrence2
                Dim RefFace ' = OldRelation.GetGeometry1( ???? )
                Dim NewFace ' = OldRelation.GetGeometry2( ???? )
                Dim Ref2RefFace = Asm_doc.CreateReference(RefOcc, RefFace)
                Dim Ref2NewFace = Asm_doc.CreateReference(NewOcc, NewFace)
                NewOccRelations.AddPlanar(Ref2RefFace, Ref2NewFace, OldRelation.NormalsAligned, Constrain1, Constrain2)
            Else
            End If
        Next
THX
Post date: 2/4/2009 2:50:10 AM
