extracting weld information
Would anyone know of a way to extract total weld bead length of both extruded and weld labels? When you use the weld label command, you select edge lines rom the model. this created a white line with attached information. Can i get to that information by get functions? if so what would i be looking for?
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Re: extracting weld information
Nathan,
A great way to see if there is API support for something is to use Jason Newells spy tool.
I took a quick look and didn't see that the weld label had any properties that were useful.
Jason T.
LMGi
www.TLMGi.com
You will probably have to do some math with the starting and ending points.
Terry Tyson
Software Automation Designer
