file properties for Solid Edge
hello, Jason,
i try to use your API for reading/writing file properties for Solid Edge documents.
The reading is ok,but i'have some problems with the writing.
I'm using windows XP and Visual Studio 2005 (Visual Basic).
Solid Edge version is the 18th update 9.
I receive this message when i try to write a file property:
Accesso negato. (Eccezione da HRESULT: 0x80030005 (STG_E_ACCESSDENIED))
Can you (or someone) help me? have you some examples?
Thanks you
(sorry for may bad English)
Posted by: Mauro Mignozzetti
Post date: 11/24/2006 2:47:42 AM
RE: file properties for Solid Edge
Hi Mauro,
can you post your code?
Cheers
Calum
Posted by: Calum McLellan
Post date: 11/24/2006 4:08:42 AM
hello Calum an thanks for your replay.
Here is my example code.
Can you help me, have you some example?
Post date: 11/24/2006 9:12:17 AM
Hi Mauro,
You set the read-only flag in PropertySetStorage.Open to True. Set it to False to write to the PropertySet.
Copy-Paste's a killer sometimes...
Cheers
Calum
Post date: 11/24/2006 10:05:28 AM
Calum,
thank you very much and it is true:
Copy-Paste is really a killer sometimes.
Mauro
Post date: 11/24/2006 5:13:10 PM
hi Calum,
i have another question for you.
When i write a file property in Solid Edge documents where this property is a value for the feature (lenght of a sheet metal for example)
the property is correctly modified, but if i open the file with Solid Edge, the feature isn't modified, why?
Thank you and sorry for my english.
Post date: 11/26/2006 8:02:19 PM
Hi Mauro,
This is a 'Feature' of Solid Edge. Unfortunately, variables that are exposed as properties are one-way. The property value is always overwritten with the variable value upon saving the file. Changing the property has no effect on the variable, we're still restricted to the Solid Edge API for that.
Cheers
Calum
Post date: 11/26/2006 9:01:21 PM
thank you.
Post date: 11/26/2006 9:08:02 PM
