file search in VB.net
Hello everyone,
is there a simple way to search for a specific file in a directory which has sub directories.
for example if I had a file called test.dft (solidedge). I want to find it and get the path location any help would be great
thanks
Paul Martz
National Steel Car
Posted by: Paul Martz
Post date: 11/25/2005 4:12:29 AM
RE: file search in VB.net
Imports System.IO
Module Module1
Sub Main()
FindFile("test.dft", New DirectoryInfo("C:\"))
End Sub
Private Sub FindFile(ByVal fileName As String, ByVal objFolder As DirectoryInfo)
Dim objFiles() As FileInfo
Dim objSubfolders() As DirectoryInfo
objFiles = objFolder.GetFiles(fileName)
For Each objFile As FileInfo In objFiles
Console.WriteLine(objFile.FullName) '
Next
objSubfolders = objFolder.GetDirectories()
For Each objSubfolder As DirectoryInfo In objSubfolders
FindFile(fileName, objSubfolder)
Next
End Sub
End Module
Posted by: Jason Newell
Post date: 11/27/2005 1:29:28 PM
Thanks Jason,
I have been pushing through this VB.Net stuff, its frustrating when processes work in VB6, but have to approach it differently in .net.
Another question, sample code that you gave me is for a module. I want to access this through my form with a button, I am having trouble getting this to work. Imports system.IO I figured out. Any guidance would be great
thanks
Paul
Post date: 11/28/2005 1:01:19 AM
Sorry, I figured it out
thanks again
Paul
Post date: 11/28/2005 1:10:23 AM
Jason,
I want to to take the objfile.fullname(once found) and save it to a string, I have been trying this, and it alway wipes out the value and keeps looping, I've tried early exits and it just keeps clearing the string values. Basically it want to push the string back to the form to use that value for other parts of the program.
Paul
Post date: 11/28/2005 4:34:13 AM
Paul,
I attached a VB.NET demo to do what you're wanting. This windows app looks and works a little like Windows 2000 search. I added some commented out code for you that allows you to find the 1st file and exit out of the recursive sub routine. Let me know if you still have any questions.
Post date: 11/28/2005 5:22:11 AM
thanks again Jason
Paul
Post date: 11/28/2005 7:39:44 AM
