form variable table to get value??
hi~ i'm sun-il kim, in korea
variable table ?
Type | Name | Value | Rule ....
i know Name
i will  have value~
help me~
Posted by: kim sunil
Post date: 11/24/2009 8:27:58 PM
RE: form variable table to get value??
Hi sun-il kim,
you must create a VariableList with "Query"
Dim objDoc As SolidEdgePart.PartDocument
Dim objVars As SolidEdgeFramework.Variables
Dim objVList As SolidEdgeFramework.VariableList
Dim myVal As Double 'or String
objApp = GetObject(, "SolidEdge.Application")
objDoc = objApp.ActiveDocument
objVars = objDoc.Variables 'have a list only with TYPE = Var
objVList = objVars.Query("Your variable name") 'if you set "*", you have a list with all variables in the table
myVal = objVList.index(1).Value
JR
Posted by: JR
Post date: 11/25/2009 7:40:54 PM
JR,
thank you for your answer...
The problem is solved.
Have a nice day~ ^^
Post date: 11/26/2009 4:04:44 PM
