gettin min/max values of asm
Is there a way to get the min/max values of asm without running on the inner parts?
consider this side view of asm ('#' are "spacers" for alignment and each '|' is a par file):
-1#0#1 -> X
I would like to know the minimum & max values of the asm in the X direction..
Thanks.
Posted by: joseph polk
Post date: 10/2/2012 6:56:57 AM
I'm not sure how to do this in the model other than retrieving info from the parts either by code or by linked variables.
In draft, all the lines are presented at the view level so it would be easier in the draft file.
There's likely an easier way in the model file as well, just don't know what it is.
Posted by: Terry Tyson
Post date: 10/3/2012 7:43:21 AM
