hide thread on a draft
Hi
I would like to know if there is a way to hide the threads in drawing views
Eric BONNAUDET
Posted by: BONNAUDET eric
Post date: 2/18/2013 6:49:47 AM
Re: hide thread on a draft
I needed to find this myself.
Eventually I came up with two methods (I am using Solid Edge ST7)
Method #1: Manual
Use the Hide Edges tool
Method #2: Thread Settings (may only work for internal edges)
Set the depiction of the thread to be the outer thread diameter in the Hole Options pane, by selecting the Nomimal diameter option (not the one selected in this screenshot!)
