holedata problems
I am programing in vb and when i use the holedata object make the hole but take the "save feature default" Holediameter....and i can't change with the code
Dim objholedata As SolidEdgePart.HoleData = Nothing
 objholedata = objPart.HoleDataCollection.Add (HoleType:=SolidEdgePart.FeaturePropertyConstants.igRegularHole, HoleDiameter:=0.0019812)
What other options are possible to change this feature1.pngHoleDiameter......?
Thanks....
Re: holedata problems
Hi
I found the problem....copy the code and paste to a new file in vb.net and add the references to the new program and it's work....
Thanks.....Everyone
