how to access hole from model
hi everybody,
i want to access holedata and hole object from model.
The problem is that i get objHoles.Count =1. And with this i can access third hole in hole collection where i actually want to access first hole.
When i use HoleDataCollection sount =3
Can anyone tell me why this is happening. Am using SE-19
 i used following procedure......
objHoles As SolidEdgePart.Holes = objDoc.Models.Item(1).Holes
"& this code to get hole count"
Dim
objHDColl = objDoc.HoleDataCollection
              holeData(j - 1) = objHDColl.Item(holeCount)
 objHDColl As SolidEdgePart.HoleDataCollectionDim holeCount AsInteger = objHDColl.CountDim holeData(holeCount - 1) As HoleDataFor j AsInteger = 1 To holeCountNext
MsgBox(objHoles.Count)
"i used this code to get hole object"
Dim
Posted by: makarand kulkarni
Post date: 9/21/2009 7:10:20 PM
RE: how to access hole from model
You made a mistake.
To get the holes collection:
To get the first hole
objHole as SolidEdgePart.Hole = objHoles.Item(1)
To get the related HoleData object
objHoleData as SolidEdgePart.HoleData = objHole.HoleData
There can be several HoleData objects in your file even if you only have got one hole. HoleDataCollection is not the collection of existing holes in your file, but a collection of different holedata definitions (Threaded, counterbored, etc) and they can exist even if they have not been applied to any hole in your file.
Hope this helps,
Julian
Posted by: Julian Guillo
Post date: 9/22/2009 12:25:18 AM
I forgot this,
Of course the hole count in your file is:
objHoles.Count not objHDColl.Count as you were doing.
Julian
Post date: 9/22/2009 12:27:33 AM
Thanks a lot Julian
Post date: 9/25/2009 9:06:14 PM
